KE70's are cool Posted January 26, 2011 Report Share Posted January 26, 2011 Hey guys, just about to put the 7K twin carb into the gfs ke30 and am wondering if anyone has put a ke70 engine cross member into a ke30 for the steering rack over the box? does it all align up? anyone done it before? i had a search no luck on the matter cheers Davey Quote Link to comment Share on other sites More sharing options...
SLO-030 Posted January 26, 2011 Report Share Posted January 26, 2011 Probably better off cutting the rack mounts off the KE70 X member and welding them to the KE3x crossmember. Quote Link to comment Share on other sites More sharing options...
towe001 Posted January 26, 2011 Report Share Posted January 26, 2011 Agree, might be easier. But you never know. Here's the dimensions for the ke3x/55 I don't have one for the ke70 but it'll give something to work from if you have the '70s x-member laying around Quote Link to comment Share on other sites More sharing options...
Killar_of_giants Posted January 26, 2011 Report Share Posted January 26, 2011 I bought an AE71 xmember because I was thinking along similar lines (only my intentions are 4AGE into KE30 hence AE71 xmember) Anywho's from memory the AE71 was approx 30mm too wide and the distance between left and right side LCA holes is greater on the AE71 xmember. Obviously with welding and cutting the xmember could be made to fit but its certainly not a direct bolt in. Ill probably be shot for this but I think the only difference between the AE71 and KE70 xmembers is that the engine mount towers on the ae71 are further spaced apart but don't take my word for it. Quote Link to comment Share on other sites More sharing options...
KE70's are cool Posted January 28, 2011 Author Report Share Posted January 28, 2011 OK cheers guys i will try it out and let you know when i do it :) Quote Link to comment Share on other sites More sharing options...
