Ke55 Pedals
hey all..been watching and reading alot of the posts...new to actually posting anything..
Ive bought a ke55 hardtop(stock)however i have a 4age sitting on a stand ready for building
biggest problem is the ke55 is AUTO!!!so has anyone got any manual pedals to suit this
vehicle??if not does anyone know what model vehicle i can use for pedals?
cheers guys
mate has been covered before try searching the site as i tried to link you the page and it didn't work. from what i remember you use a manual pedal box fro a ke55 and modify it to run a hydrolic master cylinder to work the t50 you will need to go behind the 4age.
hope you suss it
Edited by basher_ke20
yeah sorry mate i know what i gotta do,I'm chasing a set of pedals...thats the problem
i can't find any ke30-55 to pinch pedals from...so does any one have any they can part
with??or do i have to go with the willwood set???
From what I've read this should be in the wanted to buy section and a location would help us out a lot. I have a manual pedal box I just pulled from my 35, if your in Adelaide you can have them for $80.
Edited by jono1986
my mistake...I'm in cairns mate,dunno how keen u are on freightin it up tho??
Hi there Mick,
The easiest way is to get the pedal set up from a KE55 manual as this would bolt straight in, but as you know you would have to do a slight modification to the pedal box to make it suit a hydraulic clutch as the KE55’s run a cable clutch.
This is what I did to make a clutch pedal My pedal setup
I recommend send “Jono 1986” a PM because they are hard to come by up here in Cairns. (I am also in Cairns)
All the best
