alex.wilson Posted May 7, 2011 Report Posted May 7, 2011 just wondering if anyone knows that with a 0 offset would 16X8 fit onto a stock ke30? or maybe 16X7 with about a +35 offset? Quote
Chillin Posted May 7, 2011 Report Posted May 7, 2011 16x8 +-0 will not fit unless guard work is done. 16x7 +35 Should fit fine, Front may be an issue as the strut tower may foul on the tire, a 10mm spacer should fix it if so. Either way you go a very small profile tire should be used as it will reduce scrub within the inner guards. Why are you after 16's? would 14's or even 15's be an option? Quote
alex.wilson Posted May 8, 2011 Author Report Posted May 8, 2011 cheers man, 15's might be yeah, i just reckon 16's with a lower profile tyre will look better Quote
alex.wilson Posted May 8, 2011 Author Report Posted May 8, 2011 i think it might actualy be 16X7 with a +15 offset, this would be better yeah? Quote
Evan G Posted May 8, 2011 Report Posted May 8, 2011 14X7 0 offset on 195/60 tyres are perfect for 2 inch lower car i wouldnt go bigger than 15's on a 30/55 :yes: Quote
alex.wilson Posted May 8, 2011 Author Report Posted May 8, 2011 these are the rims I'm looking at getting Quote
BUZ440 Posted July 8, 2011 Report Posted July 8, 2011 i think it might actualy be 16X7 with a +15 offset, this would be better yeah? Thread revival, I have this measurement on mine, I have coil-overs up front and clear fine, you would be able to get 9's up the back also Quote
