redae71 Posted May 11, 2011 Report Posted May 11, 2011 hey i have done about 2 hours searching and have not found the answer I'm after, i recently picked up an sc14 with no pulleys bearings or coils on the front... how can i do a vbelt conversion without using any of the clutch parts i.e. make a v belt pulley fit onto the splined shaft of the supercharger... or would it be better to find a clutch and wire it to ignition power so its on all the time? goin on a 4k btw, this is a pic i found of how mine is atm Quote
Mitch-12 Posted May 11, 2011 Report Posted May 11, 2011 i have everything you need to go back to normal if you would like to buy it? for a 6pk belt just the stock stuff Quote
kickn5k Posted May 12, 2011 Report Posted May 12, 2011 I've got a spare vbelt pulley. Probably make 6-7psi on a 4k(if not a bit more). It has the support bearing for it put you will need the front clutch thingy to bolt it(which I can show you how to mod it for direct drive. I have drilled and tapped the pulley for direct drive. Free to good home you pay postage. It will atleast get you going. Stu. Quote
