May 23, 201115 yr comment_526169 HI, I went about lowering my ke10 i put 2 1/2 inch lowering blocks in the rear leafs and got the front leafs sent away and lowered 2 inches when i put every thing back in the car only sat 1 inch lower than original height! how is this possible!!? where do i go from here?? thanking you in advance Report
May 23, 201115 yr comment_526180 Hey mate.. Best thing to do is to remove the front leaf spring, Add a whiteline sway bar for it and get some thicker springs ( I think KE20 are the ones to use from memory ) Proper way: As for the rear... Go get the rear leafs gutted, everything taken off them, have the front eyelet flipped and as them to put 2 thicker leafs onto them.. I think the ones I put on mine where landcruiser from an FJ40 Dodge way for the rear: turn the leaf springs upside down Report
May 23, 201115 yr comment_526365 This is the first thing you should do to get about an inch out of the front end http://www.rollaclub.com/faq/index.php?title=Lowering_KE1x_Front_using_KE2x_parts Report
May 24, 201115 yr comment_526478 HI, I went about lowering my ke10 i put 2 1/2 inch lowering blocks in the rear leafs and got the front leafs sent away and lowered 2 inches when i put every thing back in the car only sat 1 inch lower than original height! how is this possible!!? where do i go from here?? thanking you in advance Springs can take a couple weeks to settle. Report
May 24, 201115 yr comment_526495 remove the front leaf all together, and run some decent front lowered springs- and philbey's ke20 strut top setup! Report
May 24, 201115 yr Author comment_526551 Thanks guys been a big help il put some photos of the little beast soon :D Report
