June 11, 201115 yr comment_531259 Hey guys, Hoping somebody can help me out. Trying to find the specs for a stock 3tc camshaft for comparison against some racing cams I'm checking out. Specs I'm after are: Valve lift Lobe lift Duration Lash clearance Lobe center And timing specs. Any information is hugely appreciated Cheers, Chris Report
June 21, 201115 yr comment_533960 gday - have the specs on a cam that was to be a stock replacement for a friends celica 2t but as far as i am aware 2t/2tc/3tc all share the same cam specs.... ??? Gross valve lift intake/exhaust .355"/.355" Lobe lift: .254 intake/exhaust Duration: 256/256 Valve Lash: .014 intake and .016 exhaust Lobe Center: 110 not sure about timing specs hope I could help somewhat .... :hmm: Report
June 28, 201115 yr Author comment_535698 Thanks heaps, It'll give me something to work form at the least Cheers Report
