June 21, 201115 yr comment_533854 Hi all, I am wanting to buy the hopper stoppers brake upgrade for my ae71 and will most probably be bolted to ae86 coilovers. what i want to know is if id have to run wheel spacers if i chose to run stock falcon 15's. I have contacted HS and they said they provide new hubs in what ever stud pattern, e.g 4x114.3 or 5x114.3 etc. I have been thinking of using an ED-EL xr6 lsd diff cut down for an upgrade as the brake set up would match very well, so i'm a bit stuck on whether or not to go corolla 4 stud or falcon 5 stud as i don't know if i can get blank rear rotors to get drilled to 4 stud. Any constructive opinions on what i should go with is appreciated. :thumbsup: Report
