braaap Posted June 26, 2011 Report Share Posted June 26, 2011 Ok so. ive checked all the fuses including the ones in the kick panel and ive replaced the switch at the pedal. My tail lights are staying on like I'm constantly braking. ive searched that many forums and no one is having this problem. or if they are its the switch or the fuses. so HOPEFULLY someone can help. Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted June 26, 2011 Report Share Posted June 26, 2011 If the brake lights are staying on it is more than likely the cushion the brake switch is meant to stop on has perished and it is allowing it to go to full extension and stay on.. Quote Link to comment Share on other sites More sharing options...
Chillin Posted June 26, 2011 Report Share Posted June 26, 2011 Are they the correct bulbs? the double filament ones I know it's probably not, but it may be something that has been overlooked Quote Link to comment Share on other sites More sharing options...
braaap Posted June 26, 2011 Author Report Share Posted June 26, 2011 chillin i checked the globes they are both double filament. Medicine_man i swapped the switch though i doubt two switches would have the same problem. i also noticed the left side is brighter than the right would a wire between the two clusters shorting out cause a problem like this? Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted June 26, 2011 Report Share Posted June 26, 2011 i was not talking about the switch being faulty. i was saying there is a pad it rests on to keep the contacts open / switch off till you apply the brake pedal you were saying that it stays on when your foot is not on the pedal? Quote Link to comment Share on other sites More sharing options...
braaap Posted June 26, 2011 Author Report Share Posted June 26, 2011 theres a little tab the switch screws through thats fine. yeah the lights just stay on. Quote Link to comment Share on other sites More sharing options...
braaap Posted June 26, 2011 Author Report Share Posted June 26, 2011 or do you mean on the pedal itself. sorry if i seem stupid haha. just hard picturing things with out someone pointing at them =D Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted June 26, 2011 Report Share Posted June 26, 2011 at the very tip of the brake switch there should be a small rubber pad to stop/cushion the pin of the switch from coming out until the brake pedal is pushed away giving it room to come out. When it perishes and falls away the switch pin goes straight though the hole that is now there leaving the switch at closed contact position/on. Quote Link to comment Share on other sites More sharing options...
braaap Posted June 26, 2011 Author Report Share Posted June 26, 2011 yeah i get what you mean now man. theres nothing wrong with the pad. when i put the new switch in i didnt put it back in case it didnt work. i pushed the little button in when i turned my lights on and it made no difference. so thats why I'm so confused and frustrated about why its not working. Quote Link to comment Share on other sites More sharing options...
