July 2, 201115 yr comment_536702 just like to start with a big shout to rollaclub great site you have here now to business just started the 1ggte into 87 hilux swap and I'm finding very quickly that alot of the info ive gathered is false if anyone knows anything about this swap like clearance and what radiator to use and engine mounts, coz using two passenger side 3y ones aint gonna work lol as i was told many thanks dave Report
July 2, 201115 yr comment_536726 pics may help motivate some answers as it sounds like an interesting build. good luck with the build and the WELCOME TO ROLLACLUB Report
July 2, 201115 yr comment_536746 http://www.rollaclub.com/board/topic/22628-nsw-1985-toyota-hilux-4x4-1ggte-dual-cab/page__p__266823__fromsearch__1#entry266823 http://www.toymods.org.au/forums/showthread.php?56251-Golberg-s-1GGTE-RN85-Hilux&highlight=1ggte+4wd+hilux Massive build thread: http://www.toymods.org.au/forums/showthread.php?16629-1GGZE-into-an-RN85-Hilux-Dual-Cab-2WD-Beware-lots-of-pix&highlight=1ggze+hilux Report
July 2, 201115 yr comment_536748 For good measure - How to build a V8 1UZFE + Supra 5 Speed hilux thread: http://www.toymods.org.au/forums/showthread.php?48943-Hilux-1uz-W57-%28Skid-Video!%29 Edited July 2, 201115 yr by Kebin Report
July 2, 201115 yr Author comment_536802 thanks heaps guys will post up some pics tomorrow hope in to have the motor sittin in place tomorrow Report
July 2, 201115 yr Author comment_536845 hey you wouldn't know how well the ae82 rolla radiator fitted do ya and if the fan fit in the engine bay or not???, and I'm staying with the twin setup so I'm guessing i need to bash the S#%t outta the firewall til it fits??? lol with the engine mounts I'm guessing i need them to be the same angle as two 3y passenger mounts but remade to clear the dump pipe??? i think me an my old man have sorted out the wiring the green box in that photo of the duel cab thats the circuit opening relay yeah??? if so mine didn't come with one does anyone know if i can remake the relay by using two other relays??? how did the duel cab lux sound I'm thinkin of only going 2.5" with hiflow cat and single muffler??? almost forgot was the flywheel machined to be lightened or did it need to be done for the engine to fit??? cheers again Edited July 2, 201115 yr by twinturbohilux Report
July 3, 201115 yr Author comment_536897 hey you wouldn't know how well the ae82 rolla radiator fitted do ya and if the fan fit in the engine bay or not???, and I'm staying with the twin setup so I'm guessing i need to bash the S#%t outta the firewall til it fits??? lol with the engine mounts I'm guessing i need them to be the same angle as two 3y passenger mounts but remade to clear the dump pipe??? i think me an my old man have sorted out the wiring the green box in that photo of the duel cab thats the circuit opening relay yeah??? if so mine didn't come with one does anyone know if i can remake the relay by using two other relays??? how did the duel cab lux sound I'm thinkin of only going 2.5" with hiflow cat and single muffler??? almost forgot was the flywheel machined to be lightened or did it need to be done for the engine to fit??? also did the duel cab have powersteering??? cheers again Report
July 3, 201115 yr Author comment_536898 wrong button was just askin if the duel cab had power steering Report
July 14, 201115 yr comment_539675 hey you wouldn't know how well the ae82 rolla radiator fitted do ya and if the fan fit in the engine bay or not? ae82 rad fitted sweet and had enough room for thermos.. no cutting of rad support except for cooler pipes with the engine mounts I'm guessing i need them to be the same angle as two 3y passenger mounts but remade to clear the dump pipe? yes, with the motor bolted to the factory gearbox, we custom made the mounts to suit the best position. the green box in that photo of the duel cab thats the circuit opening relay yeah??? if so mine didn't come with one does anyone know if i can remake the relay by using two other relays? Go to your local wrecking yard. Just get one out of any efi AE series corolla.. they are mounted next to the ecu.. easiest way to keep it factory... also easy to understand when diagnosing future problems. Also you will need a speed signal input to the engine ecu. you can tap into the pollution computer which you can see in the pics. how did the duel cab lux sound I'm thinkin of only going 2.5" with hiflow cat and single muffler? We had 2.5" It sounded sweet.. nice and quiet was the flywheel machined to be lightened or did it need to be done for the engine to fit??? We machined the flywheel because we fitted a new clutch. also did the duel cab have powersteering??? We were going to fit it but ran out of time.. you have to make custom lines to suit 1g ps pump Edited July 14, 201115 yr by Kebin Report
