if it is a australian delivered ae86, it will have an "S series" differential.
not the same as ke70 or ae71. and the center wont bolt in either.
the entire ke70 diff will bolt in, but you will need to use an AE71 tail shaft, as your current tail shaft wont be the right length.
whats wrong with your diff?
probably just the axel bearings.
no need to change the whole diff for that.
buy new axel bearings (about $50), pull axels out, take them to mechanic, get new bearings pressed on. put axels back in.
If you're going to replace the entire thing at least get a t-series diff (from a T-18) or even better, one with disc brakes off a Jap-spec AE86.
That way you get larger axles and option for a LSD...
  • 2 months later...
