October 2, 201115 yr comment_557365 guys, I'd love some advice before i buy the wrong HD clutch kit. i have read all the guides i can on here, and they all seem to say that a 5k clutch is 200mm in diameter, and 4k is 180mm. now, i measured up mine and its 180 mm diameter, and its def. a 5k engine. so, i assume previous owner/s has put 3,4k clutch on it, and i get the 200 mm clutch kit regardless? or do i order the 180mm? any help appreciated Report
October 2, 201115 yr comment_557372 if its 180mm its a 4k flywheel clutch. ive heard (don't quoted me!) that 200mm clutch/flywheels fit in ke70 4 speeds only! Report
October 2, 201115 yr Author comment_557399 so do i just replace it with another 180mm(4k), or go to the 200mm that 5k's should use?(as far as i know?) thanks for the reply mate edit: I'm running a ke70 5 spd Edited October 2, 201115 yr by nerfbat Report
October 2, 201115 yr comment_557400 The flywheel will be either a 3k or 4k. My thoughts, don't even bother with the exedy and go for the clutch industries brand R47N. The clutch plate i got to replace the exedy one is a hell of a lot better, same price. Bursons where i got it from. Report
October 2, 201115 yr comment_557401 the problem is your 5 speed is a 19 tooth input shaft. the 5k 200mm is 21 spline. 4k is 19 tooth 180mm. just get a HD exedy 180mm 19 spline clutch. Report
October 2, 201115 yr comment_557404 also you should changed your clutch pressure plate to suit the heavy duty clutch. Report
October 2, 201115 yr Author comment_557406 cheers mate. ill be grabbing full clutch kit, ie clutch plate, pressure plate and throw out bearing. just wanted to make sure b4 i commit. once again, thanks for your time, guys Report
October 2, 201115 yr comment_557408 so do i just replace it with another 180mm(4k), or go to the 200mm that 5k's should use?(as far as i know?) thanks for the reply mate edit: I'm running a 5 spd Use a clutch kit for a 4k from either a ke55 or ke70, 4 speed and 5 speed are the same. Report
October 2, 201115 yr comment_557409 just some prices i got when i was looking into clutchs. $100 for pbr HD $180 for extreme $280 for exedy HD Report
October 2, 201115 yr Author comment_557411 thx guys. and evan, can you show a link for them mate? or are they are lil old? cheapest i have found is 120 ish for a std kit Report
October 2, 201115 yr comment_557413 thats who ive rang around and the price ive gotten over the fone. Report
October 2, 201115 yr Author comment_557414 My thoughts, don't even bother with the exedy and go for the clutch industries brand R47N. The clutch plate i got to replace the exedy one is a hell of a lot better, same price. Bursons where i got it from. just checking them out, too, thx Rob thats who ive rang around and the price ive gotten over the fone. ah ok thanks mate Edited October 2, 201115 yr by nerfbat Report
