The MSD coils put out a higher voltage, 45,000 will get you a fatter spark. Can possibly open up plug gap.
First up, you won't notice any real performance difference in a daily/stocker/mild street car.
Secondly, you'll pay 80-90 bucks for an MSD Blaster 2, or 40-50 bucks for a Bosch GT40. The Gt40 runs about 40,000 volts. Keep it cheap and just go with that.
running a stock 2tc with weber carb. Thinking of going with the dual weber's. I was told if I do that I should get a bigger cam to get the benfits from it. re-do the head all set up for it too.
Hey Dude
If your going to rip the head off , port it, polish it, double valve springs to suit your new cam , larger valves and harden seats ( then you can run ulp 95 no flash lube :D )and maybe bronze guides. :yes:
