Hi All,
I'm doing the wiring for the custom dash layout and I'm not too sure how to;
Wire up the Alternator charge Lamp from the ( L ) – Lamp Terminal from the Alternator.
The alternator is 20V Black Top 4AGE (AE111)
My question I ask is; does the ( L ) – Lamp Terminal from the Alternator produce a positive current and I earth the other side of the Alternator light to ground.
thanks
The alternator charge light is fed ignition on one side and goes down to the alternator looking for a ground on the L terminal of the 3 pin plug. once the alternator starts charging it produces a voltage that puts the light out because you have voltage either side of the globe.
  • Upvote 1
