November 30, 201114 yr comment_568980 Hi you all I new to this site: I have swap out my 4afe motor for a 4age tvis. got the loom splice together by a pro. the problem is the car will start run for 10-15 min then cut out. it seem to be running rich because of the black smoke that comes from exhaust. my temp gauge was working when I first start car up, after a few revs the gauge drop down to cold and remain there ever since. I have change the efi sensor that locate on cylinder head on gearbox side.; still no joy? can some1 please help me with some suggestion on what to do to get this car going properly. thanks Report
November 30, 201114 yr comment_569010 What does it run like while it is running, does it seem to be on cold start (idle high) or just really fuely? Report
November 30, 201114 yr Author comment_569022 What does it run like while it is running, does it seem to be on cold start (idle high) or just really fuely? It will run ok on cold start. Then up and down before. now it just cut out once warm up. I have to keep my foot on the gas pedle to keep engine on once I get it started. It will take a few crank to get it to start. Also I notice it will take a lot of battery life to crank it so battery keep going flat. Report
December 1, 201114 yr comment_569109 Hunting is caused by a cooling system problem where the water doesn't always meet the wax pellet under the intake manifold, if it has an issue with the cooling system then it will run rich, also the temp sender for the dash is on the water outlet (top hose), have you checked to see if there is sufficient water in the system? Might also pay to check you TPS settings. Report
December 2, 201114 yr Author comment_569223 Hunting is caused by a cooling system problem where the water doesn't always meet the wax pellet under the intake manifold, if it has an issue with the cooling system then it will run rich, also the temp sender for the dash is on the water outlet (top hose), have you checked to see if there is sufficient water in the system? Might also pay to check you TPS settings. I will check it all over again. I forget to mention that I am using the 4afe radiator and fan that stays on once the key is turn to on position this why my battery keep going flat. It doesn't hunt anymore its just cut out once the engine get warm up. Report
