FOOMAN Posted February 22, 2012 Report Posted February 22, 2012 Alright so I'm trying to put my flex plate (which i think was originally from a 3k) from one 4k onto another one and for some reason a couple of the gearbox bolt holes don't line up by a few Mm. Also, on the new 4k one of the flex plates two bolt holes that hold it on is non existent. Which is quite confusing. Google has left me rather confused and irritated, especially after linking me to rotary stuff :/ Wondering if the 3k and 4k flex plates have any differences and also what difference is there between the auto and manual ones. Cheers :) Quote
towe001 Posted February 22, 2012 Report Posted February 22, 2012 Flex plate ? Or are you talking about the plate that goes between the motor and the gearbox ? Thats a sandwich plate. Auto plate (2 speed auto) is thicker and there's an "inspection hole" on the bottom side of the plate. Its for un-bolting the torque convertor from the flex plate/flywheel. I think the plate for the 3 speed (trimatic) is the same as well. But i think i threw it out, so the only thing i can say for certain is of the "inspection hole", it will have that. There's no real (or shouldn't be) difference between the 3k and 4k plates - unless its the plate for an early 3k, then there'll be a difference in bolt holes. Quote
SLO-030 Posted February 22, 2012 Report Posted February 22, 2012 Some K engines have 2 bolts that hold the sandwich plate to the block, some have 1 bolt. Not really necessary to have them as they are held in alignment by the dowels and secured by the gearbox bolts. More than likely to stop the plate vibrating around the rear main carrier/ crank. Quote
FOOMAN Posted February 23, 2012 Author Report Posted February 23, 2012 Alright cheers for that. Mine has the inspection hole so it's not the one I want. I'm fairly sure I've got the right one laying around somewhere :/ Quote
towe001 Posted February 23, 2012 Report Posted February 23, 2012 If you need one just let me know. Have two that I don't want any more. Quote
