March 5, 201214 yr comment_588535 Anyone help me out on what needs to be done to get my fenders off? Report
March 5, 201214 yr comment_588539 10mm and 12mm spanner and a socket set 1/4drive works the best, should be off memory 5 or 6 10mm bolts along the top of the guard under the bonnet, another one just in behind the front door at the top corner of the guard, and then there will be one or two at the bottom of the guard in the sil, then there will be 4 bolts in behind the bumper at the front of the guard to remove them you need to remove the bumper(if its standard bumper), look at the guard and you will see said 4 bolts to remove Report
March 5, 201214 yr comment_588547 You'll need to remove the inner wheel arch lining too. Also unscrew the aerial on the drivers guard. Report
March 5, 201214 yr comment_588721 also need to unscrew the metal rod that braces the front of your guard(just in front of the front wheel) of the body if it is still there. Report
September 5, 201214 yr comment_625201 trying to do this myself, there is one bolt along the top of the guard that is sitting underneath the strip that runs along above the bonnet (with the vents and where the wipers come through, whats it's called??) How do you remove that strip to get to that bolt? thanks in advance! Report
September 5, 201214 yr comment_625202 You'll need to take your bonnet, window wipers off and remove that piece by unscrewing some bolts/screws along the top of the fire wall. Then pull it towards the front of the car and it will slide out. Report
September 6, 201214 yr comment_625327 really? thats a real pain in the @$$ just to remove one bolt! thanks for the help though Report
