March 6, 201214 yr comment_588764 Guys, I'm in the process of sorting out engineering, and need to know the factory wheel specifications and track widths so that I can keep to original track width for engineering. I'm not interested in learning what CAN fit... i need to know what was factory on KE70 and AE71. I must find out to ensure that i chose wheels with correct offset to maintain close to factory track widths. All help would be appreciated. Witzl. Report
March 6, 201214 yr comment_588790 From what I found on google - 13x4.5" with a offset of +32mm. Which sounds a bit too much pos offset but no idea and you will not be able to fit many wheels that will keep within that size and offset. Report
March 6, 201214 yr comment_588926 I'm sure if you look at the tire placard on the door it should tell you what the original wheel sizes are Report
March 7, 201214 yr comment_589073 I'm sure if you look at the tire placard on the door it should tell you what the original wheel sizes are Done and dusted. Report
