Ok guys having a little bit of confusion I have what I've been told a 70amp rx7 Bosch alt which was in my 4door ke30 and was running fine which I have taken out and I'm going to put in my ke30 2door
Alternator
But when I had a look the wiring loom is different between both my cars and looks like they have two different regs
2door reg
4door reg??
I read up on the vl alternator upgrade and was explained that you wire the terminal to the 2pin connector
but my 2door has a 3 pin connector
Has anyone come across this or have anykind of wiring diagram any help is appreciated guys
6 pin toyota external regulator
Battery Sense (B+)
Ignition (IGN)
Charge Light (D+)
Ground (B-)
Field (DF)
Neutral (N)
3 Pin plug on Toyota external reg. alternator
Ground (B-)
Field (DF)
Neutral (N)
2 pin regulator is usally just has..
Field (DF)
Dynamo (D+)
