ShowUsYourTints Posted March 25, 2012 Report Share Posted March 25, 2012 (edited) Hi Guys, Firstly, done a search and found a few results, but they were very generic and weren't 100% suited to my application. My question is the following. Will these AE86 Camber Tops (CLICK ME) fit my KE70, that has AE86 Struts, AE86 Springs and XT130 LCAs? Direct bolt in, or is there modifications required for fitting? Thanks in advance gents. Cheers, Shazza Edited March 25, 2012 by ShowUsYourTints Quote Link to comment Share on other sites More sharing options...
snot35 Posted March 26, 2012 Report Share Posted March 26, 2012 Why don't you click on the link that says ask a question about this product? :) There would be two parts to consider. First, the plates look to have the later bolt spacing. I believe there is an early bolt spacing where all the bolts are an equal distance apart. Then there is the late spacing where one bolt is further from the bushing/bearing center. This is common to the AE86 also. If you don't mind drilling/elongating holes where the hats bolt in you'll be fine. The spring hat looks a little small for AE86 springs, but ask them to be sure. Quote Link to comment Share on other sites More sharing options...
ShowUsYourTints Posted March 26, 2012 Author Report Share Posted March 26, 2012 Hi mate, Spoke to them on the phone. They aren't 100% sure if it will fit KE70, however, from all accounts I've read, they should fit no worries, with maybe a bit of caster loss, which can be corrected via adjustable caster rods anyways, so i've bitten the bullet, and purchased them, will fit them up, and report back. Cheers, Shazza Quote Link to comment Share on other sites More sharing options...
19914afc Posted March 26, 2012 Report Share Posted March 26, 2012 Yeah, 86 and ke70's I am pretty sure have same strut tops but yeah loose a bit of castor using 86 ones. Pretty sure only series 1 TE72 (T18) and earlier (pre ke70) corollas have the equilateral triangle, I also think pre T18 may have a larger equilateral triangle pattern. Quote Link to comment Share on other sites More sharing options...
snot35 Posted March 26, 2012 Report Share Posted March 26, 2012 My '84 is equilateral. I also tried strut tops from a series 3 T18. They are also equilateral, but in a different way that does not fit a late KE70. Quote Link to comment Share on other sites More sharing options...
phat rolla Posted May 13, 2012 Report Share Posted May 13, 2012 hey id like to know if they ended up bolting straight in no dramas?? Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted May 13, 2012 Report Share Posted May 13, 2012 https://technotoytuning.com/toyota/ke70/ke70-corollalevin-camber-plates buy KE70 ones. Quote Link to comment Share on other sites More sharing options...
