crunk81us Posted June 10, 2012 Report Share Posted June 10, 2012 got 4age from an ae92 I have got most of the info i need to do the conversion into my 20. Plenty of info on ecu, wiring, intakes, etc.. just can't find the relevant info on clutch and starter. simple question, can i use the fwd starter and or clutch on a t50 rwd box? Quote Link to comment Share on other sites More sharing options...
bAKER Posted June 10, 2012 Report Share Posted June 10, 2012 rollaclub faq. all the info you need. there is a link on the rollaclub homepage. http://www.rollaclub.com/faq/index.php?title=Tech:Engine/A_Series/Converting_to_RWD Quote Link to comment Share on other sites More sharing options...
Willis Posted June 11, 2012 Report Share Posted June 11, 2012 I'm of the opinion that you'll need an AE71/AE86 starter motor. Quote Link to comment Share on other sites More sharing options...
crunk81us Posted June 11, 2012 Author Report Share Posted June 11, 2012 rollaclub faq. all the info you need. there is a link on the rollaclub homepage. http://www.rollaclub...nverting_to_RWD yes i've read that one, it says there are 2 different diamtere clutches but doesnt mention whether fwd/rwd are the same. I have a great fwd one and don't want to spend money on a new one if i don't have to. and nothing on the starters.. I guess i can wait til i get the t40/50 and bolt it up and see what happens. was just hoping someone knew off the top of their head for sure it would/wouldnt work. I think i can probably get the starter bolted in with some minor mods if need be. (grind/drill a hole into the bellhousing and tap a thread/weld a nut on the back of the steel plate) Quote Link to comment Share on other sites More sharing options...
crunk81us Posted June 11, 2012 Author Report Share Posted June 11, 2012 Oh wait.. it is there i missed it on the first 2 reads lol (dumbass) "If yours is the 212mm Clutch, you will have to buy an AE92 100KW 4AGE 212mm clutch kit (also you will have to buy a throwout bearing from an AE71/AE86, as the AE92 clutch kit throwout bearing is completely different)so i can use the clutch on it (ae92) and buy a throwout bearing. :D yay Quote Link to comment Share on other sites More sharing options...
bAKER Posted June 11, 2012 Report Share Posted June 11, 2012 correct! Quote Link to comment Share on other sites More sharing options...
the witzl Posted June 26, 2012 Report Share Posted June 26, 2012 don't forget to fit a spigot bearing into the crankshaft though!!!! FWD's don't have a spigot bearing, but you need one on RWD. Quote Link to comment Share on other sites More sharing options...
crunk81us Posted June 26, 2012 Author Report Share Posted June 26, 2012 don't forget to fit a spigot bearing into the crankshaft though!!!! FWD's don't have a spigot bearing, but you need one on RWD. did that one. thanks :) Quote Link to comment Share on other sites More sharing options...
