June 19, 201214 yr comment_610905 hey guys been looking can't find anything...I'm trying to get my 4kc out of my ke70 but the clutch cable wont come.out it goes through the plate that sits between the motor and gbox but the cable also goes through a gbox hole and.the end wont fit through any help would be awesone Edited June 19, 201214 yr by moreno180 Report
June 19, 201214 yr comment_610908 I just cut mine..... I had quick and noticed that I looked like it wouldn't fit through as well. One of the other guys may know a trick for it. Report
June 19, 201214 yr comment_610924 hi mate. its a 2 second job to do properly. simply unhook the loop from the clutch pedal and push it through the firewall hole. then pull/push it towards the boot, through the hole 'backwards' to what you think it should hope this helps Report
June 19, 201214 yr comment_610925 ie the opposite from what you have pictured Edited June 19, 201214 yr by nerfbat Report
