Perthke55 Posted January 27, 2006 Report Share Posted January 27, 2006 (edited) Ok guys, my bog stock ke55 needs to be upgraded..so I'm open to suggestions, an info on acheiving them, eg installing corona struts? lsd upgrade, brakes, engine, lowering etc, possibly making a customer instrument cluster etc. would post this in the ke forum but id rather put it here, as you guys would be of more help an are local. cheers. Jamie Edited January 27, 2006 by Perthke55 Quote Link to comment Share on other sites More sharing options...
Dan Posted February 6, 2006 Report Share Posted February 6, 2006 Well, for starters, I don't think I've said hi yet buddy; G'day! If you PM me your postal address, I'll send out that sticker :D Anyways, theres a shitload of stuff you can do to your rolla mate. The first thing I'd be doing is installing some stiffer, lower springs, and perhaps a strut brace to make the thing handle a lil better. I'm guessing she's not an auto, ay? If shes a manual and you want the car to take off a bit better, try upgrading to a higher ratio diff. Want looks? 16" rims are f@$king huge on a early rolla! Or how about tinting the windows; any car looks better rollin with dark tint. Droppin in a 5k is a straightforward drop in (thats what I've heard anyway) and supercharging a K motor is always a great idea! Theres so much to do to the early rollas, where can you start really. Just do what ever you want to do! By the way, have you got any part cars? Would be interested buddy. Cheers, Dan. Quote Link to comment Share on other sites More sharing options...
Perthke55 Posted February 8, 2006 Author Report Share Posted February 8, 2006 Well, for starters, I don't think I've said hi yet buddy; G'day! If you PM me your postal address, I'll send out that sticker :D Anyways, theres a shitload of stuff you can do to your rolla mate. The first thing I'd be doing is installing some stiffer, lower springs, and perhaps a strut brace to make the thing handle a lil better. I'm guessing she's not an auto, ay? If shes a manual and you want the car to take off a bit better, try upgrading to a higher ratio diff. Want looks? 16" rims are f@$king huge on a early rolla! Or how about tinting the windows; any car looks better rollin with dark tint. Droppin in a 5k is a straightforward drop in (thats what I've heard anyway) and supercharging a K motor is always a great idea! Theres so much to do to the early rollas, where can you start really. Just do what ever you want to do! By the way, have you got any part cars? Would be interested buddy. Cheers, Dan. Hey dan, Yea mine has the holden suspension so its a bit different to lower, as i here..yea shes a manual, what sort of diff ratios are there, an how do i instal them?i kinda would like to put a r31 lsd in if i could get one, but I'm havent really done that sorta thing so yea..not sure, id also like it to handle better, as i like to do down hill touge runs. Quote Link to comment Share on other sites More sharing options...
Perthke55 Posted February 11, 2006 Author Report Share Posted February 11, 2006 FAQ Search Google As i said i havent done that sorta stuff before, other people who have done its advice/help/suggestions arewhat I'm after. Quote Link to comment Share on other sites More sharing options...
Dan Posted February 11, 2006 Report Share Posted February 11, 2006 I think what nick is tryin to suggest is to look thru the FAQ, some blokes have written a whole lot on the best mods to do, and good ways to perform them etc. Just makes it easier when u know what you wanna do, thats all. Cheers, Dan. Quote Link to comment Share on other sites More sharing options...
Perthke55 Posted February 13, 2006 Author Report Share Posted February 13, 2006 well i want to install a r31 4 pinion lsd, but that will be a wider axle an need to be shortened?an installing is also my issue, as i havent done these sorts of things before, an the faq doesnt exactly give much info on how to instal it. Quote Link to comment Share on other sites More sharing options...
Rolla__Boy Posted February 14, 2006 Report Share Posted February 14, 2006 Well when you lay underneath the car you will clearly see what needs to be undone and done up to install the diff. Whoever you get to shorten the diff will also put the corolla mounts on it, making it a bolt in job. It's quite easy if you just have a go at changing it. Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted February 14, 2006 Report Share Posted February 14, 2006 Using the search function would have netted you this http://www.rollaclub.com/board/index.php?showtopic=202 Have a read through, he cut down a skyline diff to fit.. Quote Link to comment Share on other sites More sharing options...
Perthke55 Posted February 14, 2006 Author Report Share Posted February 14, 2006 yea i looked, but your missing my point, i don't know what to do, i never welded before, an fitting it I'm in the same boat, an the pics for it don't load up, I'm asking is for info, an help, as i said, its not something i know how to do yet. :P Quote Link to comment Share on other sites More sharing options...
Rolla__Boy Posted February 14, 2006 Report Share Posted February 14, 2006 You shouldn't need to weld? If you pay a place to shorten a Skyline diff or something similar, you can get them to put the correct mounts on it, so it will be a bolt in job. And as for fitting, aside from doing it for you, there is not much we can do? There is 4 nuts on the bottom of the leaf springs in the middle that hold the u bolts on, then there are 4 (I think) bolts holding the hand brake cables in, and they have a plastic clip that needs to be popped out, then the ends need to be slid out of the bracket under where the handbrake is in your car, there is 4 nuts and bolts holding the tail shaft on, then you need a 10mm pipe spanner to remove the brake lines, then I find it easier (mostly due to how low my car is) to remove the rear of the leaf springs and slide the diff out the back. There is 2 nuts on each leaf spring at the back to remove them. Surely if you have a look at the car you can see what needs to be done? Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted February 14, 2006 Report Share Posted February 14, 2006 yea i looked, but your missing my point, i don't know what to do, i never welded before, an fitting it I'm in the same boat, an the pics for it don't load up, I'm asking is for info, an help, as i said, its not something i know how to do yet. :P Quite obviously you DID NOT read it, It is full of information of what has to be done to fit the skyline diff, at no stage do the pictures have to load up, the pictures are not relevant. You just said you were asking for info, I spoon fed it to you on a platter and you are so ungrateful. Quote Link to comment Share on other sites More sharing options...
Perthke55 Posted February 14, 2006 Author Report Share Posted February 14, 2006 You shouldn't need to weld? If you pay a place to shorten a Skyline diff or something similar, you can get them to put the correct mounts on it, so it will be a bolt in job. And as for fitting, aside from doing it for you, there is not much we can do? There is 4 nuts on the bottom of the leaf springs in the middle that hold the u bolts on, then there are 4 (I think) bolts holding the hand brake cables in, and they have a plastic clip that needs to be popped out, then the ends need to be slid out of the bracket under where the handbrake is in your car, there is 4 nuts and bolts holding the tail shaft on, then you need a 10mm pipe spanner to remove the brake lines, then I find it easier (mostly due to how low my car is) to remove the rear of the leaf springs and slide the diff out the back. There is 2 nuts on each leaf spring at the back to remove them. Surely if you have a look at the car you can see what needs to be done? ok thats quiet informative thanks, an what do u kno about the tail shaft, there supposed to need to some modifaction..? Quote Link to comment Share on other sites More sharing options...
Dan Posted February 15, 2006 Report Share Posted February 15, 2006 What are your plans for this car buddy, I suggest perhaps a lock diff :P Go you mate, pics when you do it please! Quote Link to comment Share on other sites More sharing options...
Perthke55 Posted February 17, 2006 Author Report Share Posted February 17, 2006 well at the moment, better handiling an gearing, for a start,i don't drift, i do hills runs, an the better my car handles an accelerates for this the happier i am, i reckon for a 27year old car it goes pretty well. then maybe get the surface rust taken care of, the chrome redone an a paint job, an engine mods/interior/stereo after, i have a cordia turbo available if i want to, tho I'm not sure its such a simple thing to do. I'm going on a cruise next friday, ill try an get some shots of it then. Quote Link to comment Share on other sites More sharing options...
