Does anyone have any leads on where to find replacement rubbers for a KE16?
Particularly for the side and rear glass and tailgate seal. (I.e. the stuff that is not common with the rest of the KE1x bodies)
Maybe Scotts Old Auto Rubber Co. You could have a look and see if there is a listing on their online catalogue or take a sample in and see if he can match it.
Scott's old auto rubber do a tailgate seal that I used and it worked wel, just contact adhesives on and it's a good seal.
As for the side rear windows, I haven't looked but I think you will have trouble getting them. The ones for the opening window you might be able to ri g something up, but the fixed side window will be more tricky to find I think
Hi Philbey,
you don't happen to have a record of what extrusion he sent you? I didn't have a sample to show him so the one he supplied me did not line up so good (doesn't seal at the top)
And I figured rear sides would be a problem, was wondering if the ke25 rear quarter glass rubbers would be a close fit (at least for the corners) might have to try and find out.
