timbo Posted January 26, 2013 Report Share Posted January 26, 2013 That's what I run in my "daily". You'll get the hang of them, just like new tyres or any other upgrade. They're the max you can go for sensibility on the stock ecu, really they need a programmable ecu but you can get away with it. Later down the track you can put one in and reap the benefits that have been unlocked. People will whinge at you either way so just do what you want to do and take our advice as info and not gospel. Quote Link to comment Share on other sites More sharing options...
RhysE Posted January 26, 2013 Author Report Share Posted January 26, 2013 Yeah cheers mate this is all good info to take on board I always had my mind pretty set for 272 cams, where's the best place to buy them ? Did you do valve springs aswell or just cams ? Quote Link to comment Share on other sites More sharing options...
timbo Posted January 27, 2013 Report Share Posted January 27, 2013 I was lucky enough to buy a pair of TRD 272, 7.5mm. They don't require a shim and bucket change and can be run on stock springs. Secondhand is always a gamble but turned out to be fine. There are heaps of manufacturers, if you change springs you could get a set with some higher lift. Quote Link to comment Share on other sites More sharing options...
