Gday all When the seca gets hot it doesn't want to crank over it ranges from no movement at all to barely turning over.
When I let it cool down it has no problem at all.
Any ideas?
Cheers Geoff
pore some water over the starter motor, my mums BF Celica has the exact same problem, its probly just a lose connection that separates under heat then comes together when it's normal
