lyricallyters Posted December 3, 2012 Report Posted December 3, 2012 hey everyone bit of a newb on this site, just needing some advice on a ke30 i am piecing together. i have bought a ke70 with a clapped out body and a 4k with a 5 speed off a mate. i am planning on putting the engine and box in my 30 as i bought it as a rolling shell.. what i need to know is will the tailshaft from the ke70 line up with the ke30 diff once i put the engine in? and secondly will the ke70 fuel tank fit in my 30? is there anything i should look out for with putting a ke70 driveline in a ke30? thanks ppls Quote
B.L.Z.BUB Posted December 3, 2012 Report Posted December 3, 2012 Ok, you can use the KE30 drive shaft. The KE70 motor and box will bolt right in. The only issue you will have is the gear box shifter is further towards the rear of the car so you will have to elongate the shifter hole. The fuel tank wont fit. Quote
