December 3, 201213 yr comment_638557 I'm putting a 4k and manual box in my ke30, anything i should look out for? will it all bolt up fine? tailshaft the same length? thanks Report
December 3, 201213 yr comment_638610 If your KE30 was originally auto then the tailshaft will not fit into the K-series manual gearbox. From what I've seen, auto gearboxes use different tailshafts to manuals in the K series Corollas. But otherwise it should be a direct swap. Report
December 4, 201213 yr Author comment_638660 my 30 is just a rolling shell at the moment, and i have a ke70 that i can take any part i need from. will i need a ke30 manual tailshaft then? will the 4k wire up to the ke30 loom? thanks guys Report
