Radiator For Ke20 4Age?
Hi all
Trying to figure out what to use for a radiator on my project.
Firstly, would the original radiator be able to handle the cooling requirements of a smallport 4age?
secondly is there a radiator say of something cheap (excel, civic etc) that will do the job, and possibly have inlet and outlet on the rhs. I have been looking at threads on here but can't find where anyone says which rad they used.
Cheers :)
we use a sv21 camry rad, it's cheap new, the bottom hose is on the right side, but the top is closer to the left side.
This is in a KE70, so could be a little big for a 20.
I've got a ke20 one thats been convertered for a 4ages.. had a leak test done when i had the bottum outlet moved to the RHS... Worked perfectly... only reason i took it out was i wanted to have an alloy radiator and make it sit flush with the rad support to clean it up.
The camry one looked a bit big..
I found an EK civic radiator is about right..
ordered a new 2 core alloy one with fan and shroud. (for only slightly more than the wrecker wanted for the old one without fans etc..)
