hi all,
i have an 1.6injected ae82 manual with a crap body and have been given an ae101 1.6injected auto. will the 5sp manual from the 4ae
engine fit the 4a-fe and all the pedals, gear lingages, drive shafts etc?
also, are brake and suspension components the same
cheers
eric
Engine to gearbox and mounts - Yes, they are the same, and are interchangeable. should just need to replace the torque converter with the flywheel, and retain your original mounts...
Engine to loom, linkages, gearbox - Yes to a certain extent. it depends on if its a late model engine with port injection, or an earlier model with the injectors mounted to the head. if they are totally identical, then it should be plug and play - just take all the accessories off your old engine to bolt onto the new.
Suspension and brakes - Depends on what you want to do. Front: the struts will. the disks will, and the callipers will, but thats abot it to the extent of my knowledge. Rear: the disks will and the callipers will - depending on if you have disks already, if not then i'd probably leave it.
Edited by Bowler
