Sup.
I have been blessed with an almost rust free shell, my engine bay managed to soak up all the rust...
I have been attempting to start the repairs my cleaning out my cooling system however, shortly after I changed over my radiator it sprung a leak. All my hoses and everything aren't leaking and it's a bit of a bugger to trace back. I'll bang up some photos and if you could give me a hand identifying/tracing back the leak.
Having no actual cooling problems while driving, engine is still strong and stays cool.
It's dumping a considerable amount of water/coolant even though it's just a consistent drip.
There is no leak when the car is off, only when the coolant is flowing...
Dripping off
Highest I can trace to
Edited by B-Lugg
Yep water pump. They have a tiny little hole behind the shaft seals that is designed t leak when the seal dies, so you can tell its time to replace the pump. That's most likely where it's coming from.
