ke70cruiser Posted August 4, 2013 Report Share Posted August 4, 2013 hey guys, I'm looking at putting a 3t into my 70, what do i need todo? i have a 3t with a t50 lined up, i know i have to change the clutch set up, what else? Quote Link to comment Share on other sites More sharing options...
japlish Posted August 5, 2013 Report Share Posted August 5, 2013 easy swap, which t50 did you get? as the earlier one's from the t18/ta22 have the same spline to suit your stock tailshaft. also need: new engine mounts t50 gearbox mount will fit straight in minimal wiring for odd things (pretty much the same as 4k) radiator hoses are pretty simple to match up to stock radiator stock throttle cable or get a ae71 throttle cable as the 4k one is a little long lol exhaust is on same side but will need different front pipe thats about it..... Quote Link to comment Share on other sites More sharing options...
ke70cruiser Posted August 5, 2013 Author Report Share Posted August 5, 2013 not sure on the t50 man but i can find out, and been offered a t series cross member, but have to convert steering, is it worth doing? Quote Link to comment Share on other sites More sharing options...
japlish Posted August 5, 2013 Report Share Posted August 5, 2013 Nope it's just easier to make new block mounts, if you can't weld them make them from wood if you have to and then get them copied... Quote Link to comment Share on other sites More sharing options...
