September 14, 201313 yr comment_666986 hi people, my wife has a 89 corolla hatch, ive just rebuilt the motor to find the stock carby has no idle or mixture adjustment, I want to put a holley or down draft webber on it, is there any intake manifolds available for the holley. I'm a ford/holden man an have no idea whats available for these 4afc/4age engines. thankyou for any input would be much appreciated by myself an the wife, cheers Report
September 14, 201313 yr comment_667011 http://www.rollaclub.com/wiki/index.php?title=Tech:Engine/K_Series/Carburettor yes you can Report
September 14, 201313 yr comment_667012 Thats all K series stuff. What engine do you have. A holley would probably work, whether or not there is adapter plates available or if youd have to custom make something though.not to mention these were built for economy. I know there is a bolt on weber 32/36 option though. Edited September 14, 201313 yr by B.L.Z.BUB Report
September 14, 201313 yr comment_667013 Which engine do you have exactly, 4AC (single cam) or 4AFC (twin cam)? You can put anything you want on them, anything other than the factory gear requires adaptor plates/custom-made setups. Mixture adjustment, no, idle adjustment, yes. Report
September 15, 201313 yr Author comment_667022 4afc twin cam 1600. not looking for performance as such,as it goes alrite for what it is, just tune ability. is a bog stock rebuild but will be changing cams later, just a stage 1 or 2 cams so no valve springs required for a little more torque an reves. no extractors yet but will get some for it, motor ran perfect befor the rebuild, misses ran it dry of oil an developed a bottom end knock witch forced rebuild, I love this lil car is why we spent the money on it. THANKS FOR ALL THE HELP SO FAR BOYS, BLODY AWSOME, as I know nothing bout what can be changed or interchanged, or whats available for these things. I understand there built for economy but a well tuned carby will still be economical witch I can sort out no worries, any wore input will be greatly appreciated an I will be attending some rolla events to talk face to face with some of you, cheers will post to ya replys Report
