hi there.... I'm from m'sia..... i own a 1979 Rolla KE30...
i would like 2 know what is the rating 4 an KE30 alternator...
cos my alternator is so old until the tag on it has become unreadable...
can anyone pls help me!!!
is it 80 A or less.....
Thanks!!
hi there again.... i just changed my battery 2 days ago.......
then i have noticed that my chg ligh which i suppose the light
that shows whether the battery charging appears when i switch on the
a/c..... any guess???
the car is running smoothly... no jerks whatsoever.....
From KL, Malaysia here.
I remember when I replaced the 40 amps mechanical
regulator with a 50 or 60 amps electronic one in my
Isuzu Gemini during the 80s, the charging light was
very dimly lit up right from the moment the engine was
started.
The electrical system performed fine, and the aircon
was especially powerful and cold. The battery, which was
getting quite weak with the old altenator, virtually turned
on a new lease of life - starting the engine with a single
kick. So I think there's nothing to worry about.
35 amps is way too low if you have an aircon and other
accessories. The alternator can just barely handle the
load. I'd suggest changing to one of at least 50 amps.
I'm not sure about the mounting brackets for the KE30,
but I don't think it's much different from the KE70. My
aircon man told me that those from the Nissan Sunny,
Mazda (or Ford) Econovan and Nissan Sentra (taxi
model I think) will fit the 4K engine.
The Nissan Sentra one is a newer generation small
"pineapple" type unit, very lightweight, but he said it
is not so durable.
Edited by Tham
