Hi!
i just finished my first 4age ke70 swap. the engine is running nice and smooth, everything is great in that part.
but, my headlights don't work, hazzard don't work, cornering lights, wiper, the fan is blowing very slow even on max.
i can think about a ground fail som place, but i don't now. all this came after i put in the 4age. wierd sounds from relay and something
thank you!
Headlights and hazards: these don't pass through the ignition barrel so check your fusible links near the battery, then check all your fuses/check for power at the fuses and switches so you can find out where the circuit is broken.
Corner lights, wipers, fan: these all come through the ignition barrel in the AM1 circuit, and since your car is running (and assuming you wired it correctly) you must have power at the AM1 pin on the ignition barrel, so check all you fuses/wiring after that. You should probably get a wiring diagram: http://www.rollaclub.com/board/index.php?app=core&module=attach&section=attach&attach_id=108146
  • Upvote 1
