April 11, 200422 yr comment_7646 I have a question about brakes: I replaced the master cylinder and tried bleeding the brakes. Back brakes fine.....front brakes???....no fluid is coming from the nipples.......not even air! Do you think the master cylinder is clogged? If it is......can anyone tell me how to remove the rear piston and spring from the master cylinder? Thanks guys......I'm sure someone will know. Report
April 11, 200422 yr comment_7648 Umm... Hmm, never really heard of this happening, but could happen I guess... Maybe try to remove the front line and see if the master cylinder actually pushes any fluid out? Then at least you'll know if it's the master cylinder or not... Oh yeah, remember to catch all the fluid that comes out and keep it off the paintwork. Brake fluid is nasty on paint... Report
April 12, 200422 yr Author comment_7651 I just removed the front line ........and nothing pushes through it. Do you think it is worthwhile trying to repair.....or should I replace the master cylinder? I noticed you used a Pajero master cylinder......any complications in fitting that? Report
April 12, 200422 yr comment_7652 whats that you say? brake fluid in water bombs? yes, i know :D Report
April 12, 200422 yr comment_7659 If nothing is coming out then yes, my guess would be master cylinder is stuffed. Take it out, visually inspect it, especially in the bores. If it looks really cruddy then get a new one, they aren't too expensive. If it looks okay and you feel adventurous get a rebuild kit and have some fun :D I used a Pajero one because my brakes are rather big. With the stock brakes the Pajero unit will most likely be too big... But no, no complications apart from new front brake line. Everything else is bolt on. Report
