October 2, 201313 yr comment_668221 hey guys just finished putting the 5k in my ke25, went to start it and it turns over sooo slowly and won't start. do I need a high torque starter motor or just a newer standard starter. Report
October 2, 201313 yr comment_668242 I've got a ke70 starter on a 5k in my ke20. No warken forries. Report
October 2, 201313 yr comment_668248 All k series starters are interchangeable. Sure its not just a battery low on poke? Report
October 2, 201313 yr Author comment_668252 nah battery has 12v and tried a hilux battery too, probably need to check it's got 12v at the starter motor too Report
October 2, 201313 yr comment_668253 If you need to buy a new starter motor try getting a 7k one off a townace van about 1997 - 1999 from memory. they are high torque and are more compact in size than 3k, 4k and 5k ones and come with a heat shild to help protect it from high Exhaust temperatures. can pick them up from a wreckers for about $100. Turns over my 10.8-1 compression 7k with ease. Report
October 2, 201313 yr comment_668254 If you need to buy a new starter motor try getting a 7k one off a townace van about 1997 - 1999 from memory. they are high torque and are more compact in size than 3k, 4k and 5k ones and come with a heat shild to help protect it from high Exhaust temperatures. can pick them up from a wreckers for about $100. Turns over my 10.8-1 compression 7k with ease. Report
October 5, 201313 yr comment_668535 Sme 5k engines have one as well, it's a reduction gear starter. I've got one in mine, good bit of kit. Report
October 7, 201313 yr comment_668706 You can buy then brand new from ashdown ingram. Listed as being for a 4kj or 5kj Report
