wont the valve fall off if i do that?
ill search for some spring compressor without removing the head
any idea what its called?
Yeah, it might fall down if it goes too far down, depending where the piston is. You could tie a piece of string to the end of the valve stem just in case. But it seems like it's jammed some how. Need to work it free. Could turn it or pull it with plyers, but be careful not to scratch the valve stem, just handle it at the end.
There are a few valve spring compressor designs:
http://www.ebay.com/...0830b52&vxp=mtr
http://www.ebay.com/...5c03c9f&vxp=mtr
http://www.ebay.com/...abe74d2&vxp=mtr
Just need to be careful the valve collet doesn't fall down the engine somewhere when you remove the spring.
Edited by bruce
