January 18, 201412 yr comment_675744 Does anyone knows where the "main jet" , "air jet" and "idle jet" in separate positions????? thanks. Report
January 18, 201412 yr comment_675770 Take the carby top off. Idle jet is the small size flat bladed screw. The jet is about an inch long and has an incorporated emulsion tube. Mine was a 49. Mains are there in the fuel bowl. Mine had a 102 primary & and a 162 secondary. Air correction jets? I believe it's built into the casting. Report
January 18, 201412 yr comment_675779 I've pulled down a 4k carb off a ke55 and a ke70. The 55 had 106/152 mains & the 70 was 108/152 mains. All had 49 idle jets. All main jets are exchangeable. The idle jets are different between 3k&4k. Edited January 18, 201412 yr by GJM85 Report
January 23, 201412 yr Author comment_676030 ok thank you very much guys...... :y: :y: :y: need to fine tune my carb to maximum fuel efficiency........ Report
