leigh Posted June 10, 2014 Report Posted June 10, 2014 Plumbing up some hoses tonight and got to my brake booster Vac line, Normally goes on the manifold to get the Negative pressure. However now that the manifold pressure will be positive do I need to go infront of the blower intake? Cheers Leigh Quote
Taz_Rx Posted June 10, 2014 Report Posted June 10, 2014 Yep, Right behind your throttle plate. Why? Whenever you're wanting to brake you're going to be off the throttle hence there will be vacuum in the manifold. the one way valve in the booster line will also hold vacuum for quite a while. Quote
leigh Posted June 10, 2014 Author Report Posted June 10, 2014 Ah that makes sense... Thanks Si :y: Quote
