taco Posted June 19, 2014 Report Posted June 19, 2014 hi guys yeah kinda have a problem with the wiring. To give you a idea i swapped a running ke70 16 4age into a stock ae71 auto. So far i have done the ecu, fuel pump, coil and engine bay wire box thing. So i swapped the engine box plugs from the ke70 into ae71 just cut the two power wires and resoldered them. so i have hooked everything up and put the battery in and the hazard lights came on and when i turn the key the rad fan comes on and the fuel pump and thats it. I think the problem is in those four engine bay plugs. ..... Quote
It's_AUDM_Yo Posted June 19, 2014 Report Posted June 19, 2014 (edited) First question is does it turn on/run how it is now? Lazy people sometimes hard wire fuel pumps and fans to ignition, so if there is no COR/switches for them thats the cause. Do the hazards flash like normal? or just stay on like a light? Edited June 19, 2014 by It's_AUDM_Yo Quote
taco Posted June 20, 2014 Author Report Posted June 20, 2014 hey there. The hazard lights flash light normal and it does not start at all, just the fan and fuel pump Quote
