Saas Tacho Install Help
I'm looking for the RPM signal wire in my 76 Ke30 to install my RPM Tacho, I haven't had any luck and was wondering if someone could help me out in locating this wire. I'd greatly appreciate it.
I've got all the other wires sorted
Cheers guys!
Run a wire from the negative side of the coil.
Yep - negative side of coil.
I know my Panelvan definitely didn't have a native negative ignition wire in the loom - I wouldn't be surprised if the KE30 was the same.
