October 18, 201412 yr comment_689630 So a few days ago I got myself another ke70. The first issue is the botch job of an exhaust it has currently extractors welded to what I think is between 1.75" and 2" not stock centre muffler more piping over the diff then stops. The dude I got it off says when he got it it had twin drift pipes that ended up being ripped off by a spoon drain. So Basically need to get a new exhaust hoping to save the extractors as they are decent any suggestions of exhaust mufflers anything. I'd like a nice tone nothing too loud I like the styling off drift pipes but not the straight through lack off mufflers. So something preferably louder then stock nice note if I can have a drift pipe style for example 2" centre muffler 2" to rear muffler mounted further back and some blast pipes. But I'm unsure what setup would work best with a 4k so help me out. Also where is good and cheap for this stuff in Adelaide cheers Report
October 18, 201412 yr comment_689633 Get the longest resonator you can find to go under the passenger's seat. At the back get a tri-chamber muffler or a diagonal straight-through. The straight-through will be louder, but not quite as bad as a hot-dog. I use a tri-chamber on The Girls Ke70 and on the Altezza.. Report
