carbyarmy Posted January 28, 2015 Report Share Posted January 28, 2015 (edited) iv got this 4age with side draft carbs to get it running I had to get a internally ignited 4k dizzy made to it fit that was easy enough then to wired it up I put two wires coming of the dizzy going to positive and negative on coil then a Constance positive coming from ignition I did that and it ran straight away then I left it for two weeks and now not getting spark the wires still get power I just don't know how to check if the coil and dizzy are working properly any advise wold be awesome cheers Edited January 28, 2015 by carbyarmy Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted January 28, 2015 Report Share Posted January 28, 2015 I think the only way will be by swapping them ouit for other parts or with an auto electrician who can test them. Start by putting a spark plug on the coil lead and making sure it sparks when cranking. Just take a length of bare wire and wind it around the plug thread and earth it for am earth. Beats holding it on something! The coil should have a circuit between the positive and negative plugs, the igniter I don't know. I'm sure you've checked the 12V constant already. Quote Link to comment Share on other sites More sharing options...
carbyarmy Posted January 29, 2015 Author Report Share Posted January 29, 2015 yeah still getting constant power. iv tryd a new coil but still no luck just hoping that's its not my new dizzy i got made for it Quote Link to comment Share on other sites More sharing options...
