Superpro Poly Rear Spring Bushes
Finally fitted the Superpro poly bushes. I tried the teflon tape on the pins in the leaf shackles and front pins.
I also fitted superpro inner lca bushes, caster bushes, sway bar link bushes. Swaybar pivot bushes will be done when the swaybar turns up.
I used the supplied clear silicone 'wp grease' and smothered every surface I could, including the surfaces on the car that would be in contact.
No squeeks after a few hundred kms and a trackday drifting. The handling and steering improvement is dramatic, very happy with the results.
