June 24, 201511 yr comment_698172 Hello rollaclub. I am currently at the final stages of building my ke70 4age 16v and i was wondering if the blacktop clutch and flywheel are interchangeable with the 16v engine. What is the benefit or effects with this mod. And what do i need to complete it? - blacktop clutch kit, flywheel - 16v clutch fork - 16v throw out bearing? Thanks in advance Report
June 24, 201511 yr comment_698194 In my 4AGE powered AE71, I'm using the blacktop flywheel, the late (smallport AE92) pressure plate, and disc. When I was using the T50, it all worked along with the T50 throwout bearing and clutchfork. Get the flywheel, and pressure plate balanced... Benefit:over a kilo lighter, yet it is all OEM Report
