Jelterkun
  1. Hello rollaclub. I am currently at the final stages of building my ke70 4age 16v and i was wondering if the blacktop clutch and flywheel are interchangeable with the 16v engine. What is the benefit or effects with this mod. And what do i need to complete it? - blacktop clutch kit, flywheel - 16v clutch fork - 16v throw out bearing? Thanks in advance
  2. Hello there I am in the progress of installing the rear axle of a ae86 and the technotoytuning brake kit in the front. But i am wondering if the brake master cylinder and booster will be enough for the brakes. Anyone can help me this? And knows what cylinder i will have to use. :) Thanks
  3. After a lot of searching i still didn't manage to find these type of lights. Anybody that can help me out? I saw them on some oldschool japanese cars like this one.
  4. I guess its a jdm one, not sure though. Its most certainly not a ADM one since its coming from the uk :)
  5. Ok thanks! Yes, my gearbox is a T50 with a ae86 tailshaft
  6. Hello there rollaclub. I'm busy building my ke70 and i have the chance of buying a fresh rebuilt AE86 rear axle with cusco 2 way fitted 4.7 weir CWP all new seals and bearings, solid pinion spacer big shafts. only done 600 miles since rebuild, complete inc discs and calipers. And now i was wondering if the axle will go in no problem in my KE70. I have read that it would fit with ease but i just want to ask it in here to make sure. I also have a Ae86 driveshaft to do the complete 4age conversion. Thanks
  7. Thanks for the info already! Right now i have the complete AE86 setup in front including the big brake kit from T3. You reckon this will be enough? Because now i know i don't have to worry all to much about the axle i want to know if the drum brakes will sufice. Thanks
  8. Hello rollaclub I have a question about my 4age 16v conversion. Will a standard KE70 rear axle be enough to handle the abuse of a stock 4age 16v with minor mods? Or do i have to search for a ae86 rear axle? Because in my country they are really rare and super expensive. I'm not planning to use my car for drifting or racing. It will be just a street car. Thanks
  9. Well, when i order the 4-links for a ke70 and ae86. In my shopping cart is says that i have 2 times the 4-links for AE86, same for lateral bar and tension control rods so i guess they are the same. I don't really believe that some stuff is waste of money because i don't like to do half work. I'm planning on building this car to my "show" car and not a drif missle or some kind of wrecked KE70 with the rust covered away by fibreglass... Thats why i want to order the best possible parts i can get for my car so it will last for a long time. No, thanks for the tip.
  10. Ok, thanks for the advice. One more thing. I'm planning on buying a lot from technotoytuning in 1 buy. I'm going to write my list of things here, and i would appreciate it if somebody here could tell me if all these things will fit onto my KE70. AE86 big brake kit (t3 kit) AE86 OEM hubs AE86 4-links AE86 lower control arms AE86 outer tie rods and steering knuckles AE86 tension control rod AE86 lateral bar/panhard rod I already bought the AE86 BC racing coilovers. Will these parts all fit? Because i have doubt about the tension control rods. Remember that these are all from Technotoytuning. Thanks
  11. Well the only thing i can't do is the wiring. And i can't find a decent tutorial.
  12. Hello there I'm the owner of a ke70 and i'm planning to do the 4age conversion alongside upgrades to the suspension (coilovers, ae86 suspension all round, ae86 brakes, etc) Now i need some advice on whether or not do the engine conversion first and then the suspension or vice versa? The suspension i can do no my own but the engine conversion i cannot. So what do you guys recommend doing first? Thanks in advance
  13. i want to drop 5 to 6 cm ( 2.5 inch) Isn't cutting springs dangerous? I mean, nobody really recommends it. Well i am willing to pay those prices for a KE70. But AE86 springs do fit on a KE70 rear strut? I just wanna know this
  14. Hello fellow car enthusiasts I'm the owner off a 1981 toyota corolla KE70 and i have a question about lowering the rear suspension for this car. I have read multiple times that there is no option to put coilovers in the rear unless you strenghten the chassis. Because i have no knowledge about that i want to go with lowering springs. What i have read is that if i have a KE70 younger then 1982, AE86 springs will fit in the rear. Is this true? If so, will these springs fit in the rear? https://technotoytuning.com/toyota/ae86/swift-japan-6kg-rear-lowering-springs-ae86-corolla If so, can i use adjustable koni shocks in the rear as well? Or do i need the AE86 strut? Now i am starting this topic i just want to get some verification if this setup is right for the front suspension: AE86 Coilovers AE86 Steering arms AE86 Disc rotors & brake calipers AE86 Front wheel bearings I know that this has come up many times but i can't seem to find some good answers. Also, i live in the netherlands so king springs is not really an option for me. THanks in advance
  15. Anyone knows where these side marker lights come from?! And where you could buy them.
