Need Some Advice
Hello there
I'm the owner of a ke70 and i'm planning to do the 4age conversion alongside upgrades to the suspension (coilovers, ae86 suspension all round, ae86 brakes, etc)
Now i need some advice on whether or not do the engine conversion first and then the suspension or vice versa?
The suspension i can do no my own but the engine conversion i cannot.
So what do you guys recommend doing first?
Thanks in advance
If you can do suspension and brakes you can do a 4age engine conversion!
But yeah suspension and brakes first, while collecting parts for your 4age.
Well the only thing i can't do is the wiring. And i can't find a decent tutorial.
Ok, thanks for the advice.
One more thing. I'm planning on buying a lot from technotoytuning in 1 buy.
I'm going to write my list of things here, and i would appreciate it if somebody here could tell me if all these things will fit onto my KE70.
AE86 big brake kit (t3 kit)
AE86 OEM hubs
AE86 4-links
AE86 lower control arms
AE86 outer tie rods and steering knuckles
AE86 tension control rod
AE86 lateral bar/panhard rod
I already bought the AE86 BC racing coilovers.
Will these parts all fit?
Because i have doubt about the tension control rods.
Remember that these are all from Technotoytuning.
Thanks
I have large doubts about the 4 link, the US have different diffs to us.
What do you plan on using this car for?
I would say half of that stuff is a waste of money.
I'd just go 86 brakes and get new rotors and some good pads like project mu.
If you just want a bit longer control arms I'd go KE30/55/XT130 or look up the other options.
Only bother with the knuckles/tierods if your drifting.
Tension Rods look fine to me and again if unless your planning on drifting or heavy track work I wouldn't bother.
But by all means go for it if you want to spend the dosh
Well, when i order the 4-links for a ke70 and ae86.
In my shopping cart is says that i have 2 times the 4-links for AE86, same for lateral bar and tension control rods so i guess they are the same.
I don't really believe that some stuff is waste of money because i don't like to do half work.
I'm planning on building this car to my "show" car and not a drif missle or some kind of wrecked KE70 with the rust covered away by fibreglass...
Thats why i want to order the best possible parts i can get for my car so it will last for a long time.
That's going to cost you a fortune!
Does the big brake it come with brake caliper brackets?
No, thanks for the tip.
