Hello there rollaclub.
I'm busy building my ke70 and i have the chance of buying a fresh rebuilt AE86 rear axle with cusco 2 way fitted 4.7 weir CWP all new seals and bearings, solid pinion spacer big shafts. only done 600 miles since rebuild, complete inc discs and calipers.
And now i was wondering if the axle will go in no problem in my KE70.
I have read that it would fit with ease but i just want to ask it in here to make sure.
I also have a Ae86 driveshaft to do the complete 4age conversion.
Thanks
Yes it will bolt in no problems, depending on your gearbox the tailshaft may be an issue. If its a T50 then you need a JDM tailshaft or an AE71 front half and TE72/T18 rear half.
