September 7, 201511 yr comment_699927 Has anyone lowered their ae92 before, liftback in particular.The coilovers i bought have a bracket for the sway bar end link but the end link is not adjustable so the coilover basically has to sit at stock ride height to fit, just curious if anyone has found a way around this. Report
September 8, 201511 yr comment_699934 Has anyone lowered their ae92 before, liftback in particular.The coilovers i bought have a bracket for the sway bar end link but the end link is not adjustable so the coilover basically has to sit at stock ride height to fit, just curious if anyone has found a way around this. Are you trying to do only one side at a time? There shouldn't be an issue with the sway bar links not lining up as a lowered car is the same as a stock-height car heavily loaded, but if you're only doing one corner at a time then the rear suspension is being unevenly loaded and the sway bar would be trying to counteract that - if you jack the whole of the car up at the same time it will relieve the load on the sway bar and it should be easier to fit. Report
September 8, 201511 yr Author comment_699935 Yeah i am doing one corner at a time, gonna need to find some jack stands, cheers. Report
