Gearbox is usually a T50 from a ae71 or ae86.You will have to move the shifter hole back about 17-20mm no tunnel mods for a t50 box.
Diff depends on how hard of a time you give it ive heard of stock diffs lasting ,years or weeks.
T-series diff out of early celica (ta22)are about the right width,r31 nissan diffs seem popular ,hilux diffs are heavy but unbreakable?.
Which ever diff you go with remember that a custom drive shaft will be needed.
Peddle box can be converted with a bit of thought.or I think ke converstions do exchange pedal boxs (not 100% on this)
The slave cylinder and master cylinder can found on epay ta22 or ae71.
rob
